ReflectingMe
Mar 15, 2024Aspirant
ReadyNAS DUO V1 - issues trying to use RAIDar on Mac or Win11
Hi All - I have kindly been given a ReadyNAS DUO V1, but am experiencing some issues when trying to use RAIDar on my Mac Studio / iMac / Win 10 / Win 11. I have installed 2 * WD RED 4TB drives in th...
- Mar 23, 2024
So the outcome of this is that I have set up the Netgear ReadyNAS in RAID 0 configuration with two new Seagate 2TB drives. It is a very old NAS, and apparently is also very slow, so I decided to put it to use as a scratch / temporary storage drive for unimportant and non essential files.
I have managed to update the ReadyNAS to the latest firmware, but given that SMB1 is not supported by default on Windows10 or Windows11 (which I use via parallels), and is also not supported on any recent MacOS version - this unit is not something I will spend much time using.
For the interim I have purchased a 2 bay WD drive with 2 x 4TB drives configured in RAID 1 while I research the whole NAS market in more detail. In time I will likely purchase a 4 bay QNAP / Netgear or similar.
Thanks to everyone who has replied here with what is superb information. Thank you.
ReflectingMe
Many thanks Sandshark, and Stephen, and yes, despite being a bit of a geek, I am totally new to NAS stuff, learning fast!
So, I used Firefox as instructed, and so doing managed to successfully update the firmware to 4.1.16.
I will have a look through the settings, amend them as required, save, then revert that Firefox setting back to 3 instead of leaving it at 1.
And gotcha re the 4TB drive only showing 2TB. I may purchase two 2TB drives and use those in the ReadyNAS Duo, as well as looking for a 2 drive enclosure to house my two 4TB WD RED's.
Thank you very much both, pretty amazed at this level of support for a long gone legacy Netgear NAS device. I appreciate it is old but it might serve as a simple file store or Time Machine backup device.
Mar 15, 2024Guru - Experienced User
You'll either need to leave the setting at 1, or apply the mod to virtual.conf in this thread:
