2trees's avatar
2trees
ReadyNAS Duo V1 Capacity max.
I note from the original HDD compatibility listing, that my current unit will accept 1.5TB units. As the model reccomended is no longer available could you please advise current approved drives, greater than the two 750 GB HDD insitu. Your advice much appreciated
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Do you use disk spin-down? If so, disable it and reboot the NAS.
  • StephenB's avatar
    Disk Spindown on the NAS, not the PC. With frontview select system, then power.
    I suggest that at some point you should "walk through" the frontview menus to help you understand the various settings and features better.
ProSupport for Business
