Lucos
Sep 29, 2015Aspirant
ReadyNas Duo V2 - After restart, nothing works
Hi guys, After restarting my ReadyNas Duo V2, I lost all my acces (SMB, DLNA, SSH, Dashboard). I perform an OS reinstall by boot menu, but nothing changes. I tested open ports from my Neywork, ...
Lucos
Hi vandermerwe,
Thanks for your answer.
It's a ReadyNas Duo v2 (I verified with the guide you sent me).
The firmware version is RAIDiator-arm-5.3.10 (I found the last System Update Status email, from 2014/12/08).
The power button and Disk 1 led are on.
Raidar don't see the nas.
I didn't recieve any messages about disk errors
For ssh, i made a mistake. It could not work has i desinstall SSH add-on few month ago. But 22 port is not open.
There's just one disk. WD Green - 3,5'' 2000 Go - IntelliPower - 64 Mo - SATA III 6 Gb/s
What do you mean by "test the disks using vendor tools on a PC" ? Test the disk with an external usb hard drive box ? I don't have one at home ...
Lucos
mdgm-ntgr
Sep 29, 2015NETGEAR Employee Retired
Well it would be better to hook the drive up to an internal SATA port in your PC and test it using WD Data LifeGuard Diagnostics.
