Lucos
Sep 29, 2015Aspirant
ReadyNas Duo V2 - After restart, nothing works
Hi guys, After restarting my ReadyNas Duo V2, I lost all my acces (SMB, DLNA, SSH, Dashboard). I perform an OS reinstall by boot menu, but nothing changes. I tested open ports from my Neywork, ...
Lucos
Hi vandermerwe,
Thanks for your answer.
It's a ReadyNas Duo v2 (I verified with the guide you sent me).
The firmware version is RAIDiator-arm-5.3.10 (I found the last System Update Status email, from 2014/12/08).
The power button and Disk 1 led are on.
Raidar don't see the nas.
I didn't recieve any messages about disk errors
For ssh, i made a mistake. It could not work has i desinstall SSH add-on few month ago. But 22 port is not open.
There's just one disk. WD Green - 3,5'' 2000 Go - IntelliPower - 64 Mo - SATA III 6 Gb/s
What do you mean by "test the disks using vendor tools on a PC" ? Test the disk with an external usb hard drive box ? I don't have one at home ...
Lucos
DaneA
Oct 05, 2015NETGEAR Employee Retired
Hi Lucos,
I just want to share this link below where you can download the Windows version of the Data LifeGuard Diagnostics:
http://support.wdc.com/downloads.aspx?lang=en
DaneA
NETGEAR Community Team
- LucosOct 12, 2015Aspirant
Hy guys, thanks for your answers.
I tested several way to restore my data, but seems to be lost : the HDD is dead.
- WD Data Life guard was not able to analyze the disk
- HDTunes displayed bad sector from the begining of the disk that HDD Regenerator was not able to fix
- I try to clone the data partition of my disk that seems to be safe, but HD clone was not able to do it.
With a new disk the ReadyNas is now working.
I have been able to find the majority of my datas from differents backups on my PC, external HDD but not all :(
Now I'll wil keep 2 disks in ReadyNas and will make reguler external backups.
Luc
- DaneAOct 12, 2015NETGEAR Employee Retired
Hi Lucos,
I am sorry for that. However, at least you still have majority of your data.
Now I'll wil keep 2 disks in ReadyNas and will make regular external backups.
I am glad that your NAS is working fine using a new disk. Having regular external backups would be good practice. :)
DaneA
