convergent
Dec 30, 2012Aspirant
ReadyNAS Duo V2 - How to erase old NV+ drives
I have an old Infrant vintage ReadyNAS NV+ that has dropped a power supply again. I think I want to just replace the unit, as I'm using it to backup another NAS and don't want to keep fussing with th...
mdgm-ntgr
Dec 30, 2012NETGEAR Employee Retired
You could try doing a factory default with the disks you want to wipe installed: http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu
It may not work though and come up with corrupt root due to the different RAID format.
