convergent
Dec 30, 2012Aspirant
ReadyNAS Duo V2 - How to erase old NV+ drives
I have an old Infrant vintage ReadyNAS NV+ that has dropped a power supply again. I think I want to just replace the unit, as I'm using it to backup another NAS and don't want to keep fussing with th...
Dec 31, 2012Guru - Experienced User
That is true, unless your NAS happened to be one that was shipped with a faulty PSU.
convergent wrote: I thought the warranty replacement was for machines less than 5 years old. My ReadyNAS NV+ is over 5 years old.
viewtopic.php?t=10259
yoh-dah wrote: A small percentage of ReadyNAS NV (revision B) and NV+ owners with low-noise fanless power supply unit (PSU) may encounter a premature failure of the PSU due to elevated temperature. The ReadyNAS systems affected have Serial numbers between 000DA2010FFE and 000DA2016000. If you are unsure if your serial number falls within the hexadecimal range, you can use a hex calculator. (Click hex and overwrite the '0' with your serial number and click dec. If the number falls in the range of 58552553470 and 58552573952, then you should proceed with this service action.) Owners of ReadyNAS NV revision A who have replaced their original fan with the newer fanless PSU could be affected as well.
Though if Netgear already replaced your PSU, they likely wouldn't do it again.
