amadlmayer
Sep 01, 2017Aspirant
ReadyNAS Duo v2 - ReadyCLOUD not supported - Problem with ReadyNAS remote
I understand that ReadyNAS DUO v2 won't work with ReadyCLOUD. Question: how to have a remote access in the future? The last Android update won't let the ReadyNAS Remote start - and the ReadyNAS Remot...
DaneA
Sep 24, 2017NETGEAR Employee Retired
I just want to follow-up on this. Let us know if you have further questions.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
amadlmayer
Sep 30, 2017Aspirant
Thanks for your feedback and the proposed solution via FTP.
Some 4 years ago I was using FTP to access my ReadyNAS remotely, after an update of my router FW I was not able to make it work...than I used the ReadyNAS remote app on my smartphone and everything was fine. Now recently the ReadyNAS remote app doesn't work anymore and there is no new version available in Google Play. That means I will try harder to make FTP work again....
kind regards
Fredi
- DaneAOct 02, 2017NETGEAR Employee Retired
I'm afraid to inform you that the ReadyNAS Remote is already discontinued as of September 30, 2017. Kindly read the announcement here.
Is your router a NETGEAR device? If yes, I suggest you to post your concern on how to configure port forwarding on the appropriate NETGEAR Community board or open a chat or online case with NETGEAR Support for assistance.
DaneA
