rads_100
Jul 29, 2019Aspirant
ReadyNAS Duo V2 boot issues
Hi, I have Duo V2 with 5.x firmwarewith 2x2tb WD drives It has been working fine for past 5-6 years. but last week it said 'corrupt root' upon lookng up, i tried restore and os restore. bot...
- Jul 29, 2019
Start by testing the drives in a Windows PC with WD's Lifeguard software. I recommend running both the non-destructive extended test, and the full destructive "write zeros" test.
If both drives pass these tests, then put them back in the NAS and power it up. The NAS should then do a factory install (no need to use the boot menu, since the disks are blank).
rads_100
I have deleted the partitions on both of them, is the test necessary ?
Disk test takes like forever to complete. With my currect weather state im not sure i can keep running for more that 4-5 hrs.
I also did try normal boot the first time i booted the deleted drives.
Jul 29, 2019Guru - Experienced User
I think so, yes. I suspect at least one of the disks has failed.
- rads_100Jul 30, 2019Aspirant
Good news. Its up and running now.
What i did.
- ran extended tests on both disks,
- scan reported some sector errors, which i repaired.
- poped in the disk, booted in setup mode.
- ran volume check on nas, no errors.
Thank you StephanB, you sir are a rockstar.
- StephenBJul 31, 2019Guru - Experienced User
I'm glad I was able to help. :smileyhappy:
I suggest keeping an eye on the SMART stats on the repaired disk. I haven't had a lot of luck reallocating bad sectors myself - usually the disk continues to fail (with more bad sectors).
