scotty83
Jul 22, 2014Aspirant
ReadyNAS Duo v2 factory reset loop [SOLVED]
I'm new to the ReadyNAS world but I'm a systems administrator so technical answers are fine for me. I've recently purchased a new, old stock ReadyNAS Duo V2 and I'm having issues with a constant facto...
mdgm-ntgr
Jul 22, 2014NETGEAR Employee Retired
This is typically caused by doing an aborted secure erase when doing a factory default.
If it is this issue it is a quick fix.
Have you contacted support?
