Timbo14
Nov 12, 2015Tutor
ReadyNAS Duo v2 Firmware upgrade
I've received an email from Netgear Support advising me to upgrade my Firmware to V4.2.28. My current Firmware is V4.1.14, which I thought was the latest. However, when I visit the Support Download...
Nov 12, 2015Guru - Experienced User
Timbo14 wrote:
I've received an email from Netgear Support advising me to upgrade my Firmware to V4.2.28. My current Firmware is V4.1.14, which I thought was the latest. However, when I visit the Support Download Centre V4.2.28 is not listed as an available download. I logged into my NAS and started the UPDATE Process where it proceeded to re-install V4.1.14.
The email also states that this Firmware version will be the last for this product as it is reaching EOL.
I'm confused! Can anyone enlighten me as exactly which Firmware version I should be using.
Many Thanks.
Timbo14
First of all, you have a duo v1 (read this: http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/ )
Second, you shouldn't have received that email. Your duo is already EOL (some years back).
4.1.14 is the current firmware for your NAS. There is a 4.1.15 beta you could also use which has a couple of security patches. I'd assume that there won't be any more updates to 4.1.x firmware either (though hopefully they will release 4.1.15).
Timbo14
Nov 12, 2015Tutor
Hi StephenB, thanks for your response. I'm surprised that you say I have a ReadyNAS Duo v1, it clearly states on the label affixed the underside of the NAS that is is a ReadyNas Duo v2. Your enclosed link for me to establish which I actually have is "Page not found".
For info, the Serial No is: xxx
Timbo14
- StephenBNov 12, 2015Guru - Experienced User
For info, the Serial No is:xxxx
Timbo14
The link is fixed - the closing ) somehow got included.
All 4.1.x systems are v1s. If you had a v2 it would be running 5.x.x firmware. Read the link - the short story is that the label doesn't mean what you think.
- Timbo14Nov 12, 2015Tutor
Thanks again StephenB. Having now seen the post, its a bit clearer, and you are right, it is a v1!
I'll ignore the email and sign-off on this now, thanks again.
Regards
Timbo14
- cpu8088Nov 12, 2015Virtuoso
duo v1 has usb2 at the back
duo v2 has usb3 at the back with the blue plastic connect
