Timbo14
Nov 12, 2015Tutor
ReadyNAS Duo v2 Firmware upgrade
I've received an email from Netgear Support advising me to upgrade my Firmware to V4.2.28. My current Firmware is V4.1.14, which I thought was the latest. However, when I visit the Support Download...
Timbo14
Nov 12, 2015Tutor
Hi StephenB, thanks for your response. I'm surprised that you say I have a ReadyNAS Duo v1, it clearly states on the label affixed the underside of the NAS that is is a ReadyNas Duo v2. Your enclosed link for me to establish which I actually have is "Page not found".
For info, the Serial No is: xxx
Timbo14
Nov 12, 2015Guru - Experienced User
For info, the Serial No is:xxxx
Timbo14
The link is fixed - the closing ) somehow got included.
All 4.1.x systems are v1s. If you had a v2 it would be running 5.x.x firmware. Read the link - the short story is that the label doesn't mean what you think.
- Timbo14Nov 12, 2015Tutor
Thanks again StephenB. Having now seen the post, its a bit clearer, and you are right, it is a v1!
I'll ignore the email and sign-off on this now, thanks again.
Regards
Timbo14
- cpu8088Nov 12, 2015Virtuoso
duo v1 has usb2 at the back
duo v2 has usb3 at the back with the blue plastic connect
- StephenBNov 12, 2015Guru - Experienced User
And Duo v2 says "Duo v2" on the front :smileysurprised:
It is confusing for people who are going by the back labels - Netgear should have used different branding for the v2 platforms.
