Timbo14
Nov 12, 2015Tutor
ReadyNAS Duo v2 Firmware upgrade
I've received an email from Netgear Support advising me to upgrade my Firmware to V4.2.28. My current Firmware is V4.1.14, which I thought was the latest. However, when I visit the Support Download...
Nov 12, 2015Guru - Experienced User
Timbo14 wrote:
I've received an email from Netgear Support advising me to upgrade my Firmware to V4.2.28. My current Firmware is V4.1.14, which I thought was the latest. However, when I visit the Support Download Centre V4.2.28 is not listed as an available download. I logged into my NAS and started the UPDATE Process where it proceeded to re-install V4.1.14.
The email also states that this Firmware version will be the last for this product as it is reaching EOL.
I'm confused! Can anyone enlighten me as exactly which Firmware version I should be using.
Many Thanks.
Timbo14
First of all, you have a duo v1 (read this: http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/ )
Second, you shouldn't have received that email. Your duo is already EOL (some years back).
4.1.14 is the current firmware for your NAS. There is a 4.1.15 beta you could also use which has a couple of security patches. I'd assume that there won't be any more updates to 4.1.x firmware either (though hopefully they will release 4.1.15).
erchbox
Nov 12, 2015Aspirant
I also received the email from Netgear today.
Where can I find the 4.1.15 beta to download it?
- StephenBNov 12, 2015Guru - Experienced User
- themastahNov 12, 2015Tutor
Appreciative for this thread. No idea why I got this email and irked I went through so much trouble that seems to be for naught as the update doesn't apply to me (I have a Duo v1).
I'm surprised to see I'm runing 4.1.19, though, and of course no idea how or when that happened as it's been a few years. Anyway, thanks.
