compact
Jul 11, 2012Aspirant
ReadyNas Duo V2 or
NetGear ReadyNAS Duo V2 £99.99 http://www.dabs.com/products/netgear-re ... nas&src=16 and the NetGear ReadyNAS NV+ V2 £159.99 http://www.dabs.com/products/netgear-re ... 0542&src=3 Is there a...
HERBIEO
If its a NV+ v2 its identical except for the extra 2 bays which allso gives you RAID levels 5 (Flex-RAID) support, and LCD display on front.
see Comparison chart > http://www.netgear.com/images/ReadyNAS_Comparison_Home_v218-57079.pdf
Edit: are you sure you have a duo v2 because in your profile it says Duo if you are not sure look here > http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
Because if you have a Duo v1 then yes they are different.
