Carnaged
Dec 01, 2012Tutor
Readynas Duo V2 speed drop
Hi all, After the unit upgraded to the latest firmware my Readynas has been much slower than before, I used to get 100MB/s read and 59MB/s Write and now I get around 36MB/s Write and around 49MB/s ...
Carnaged
Dec 06, 2012Tutor
HERBIEO wrote: Average read/write speeds for DUO v2 are probably between 30-50 MB/s what you have to remember is as you copy more data to the volume and run more addons the speed is going to drop a bit due to resources being used and the time it takes to seek the hard disk for data, these are my average speeds 40 MB/s Read and 35 MB/s Write and i know that is not a network limitation because i have benched my router at 112 MB/s throughput.
Thanks for the reply and I would accept that however the device has been rock solid since January when I bought it and has always maintained a 60MB/s transfer. I am now running 5.3.5 and I don't use any apps or extras this is purely as streamer. I have also just put a new 3TB drive in, I can't think what is slowing it down as its nothing but a streamer.
