motah33
Oct 12, 2012Aspirant
ReadyNAS Duo won't update with latest firmware
Hi, I've had this problem for a while. Every time I try to upgrade the firmaware using the GUI, I eventually get a message back saying that the update failed: Fri Oct 12 17:12:13 WEST 2012 Probl...
mdgm-ntgr
Oct 21, 2012NETGEAR Employee Retired
motah33 wrote: It's been running for a while now and I noticed the squence with the disk1/disk2 leds went as follows: 10-01-11-00 (I think).
That just indicates the test is running.
motah33 wrote:
Then, the act led came on and the disk1/disk2 leds went off. It's been stuck in this state for a long, long time whereas the other sequences went quite quickly. I don't know if the tests are any differenct with the act led on but it certainly stuck here. If this is signifying a memory problem, then what is the spec of original memory in the Duo so that I can get a replacement?
I think it should be both disk LEDs lit when it's finished but I'm not sure. Maybe the result when it's finished would be both LEDs off. Have you tried powering off the NAS and running the test a second time?
