motah33
Oct 12, 2012Aspirant
ReadyNAS Duo won't update with latest firmware
Hi, I've had this problem for a while. Every time I try to upgrade the firmaware using the GUI, I eventually get a message back saying that the update failed: Fri Oct 12 17:12:13 WEST 2012 Probl...
motah33
Oct 21, 2012Aspirant
May have to run the memory test again. This time, it ended up with all 3 leds off for quite a while and so I switched it off. I hit the power button and I had to wait quite a while before it rebooted itself. I'll run the test again to see if it does it again. It does the sequence with disk 1 led being on and then you can see it moving through a pattern.
