motah33
Oct 12, 2012Aspirant
ReadyNAS Duo won't update with latest firmware
Hi, I've had this problem for a while. Every time I try to upgrade the firmaware using the GUI, I eventually get a message back saying that the update failed: Fri Oct 12 17:12:13 WEST 2012 Probl...
motah33
Oct 21, 2012Aspirant
readynas:~# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/hdc1 1.9G 361M 1.5G 19% /
tmpfs 16k 0 16k 0% /USB
/dev/c/c 462G 272G 190G 59% /c
readynas:~#
readynas:~# df -i
Filesystem Inodes IUsed IFree IUse% Mounted on
/dev/hdc1 256000 10697 245303 5% /
tmpfs 7073 1 7072 1% /USB
/dev/c/c 15204352 111733 15092619 1% /c
readynas:~# ls -la /tmp
total 123308
drwxrwxrwt 4 root root 4096 Oct 21 06:09 .
drwxr-xr-x 22 root root 4096 Oct 21 06:10 ..
drwxr-xr-x 2 root root 4096 Oct 21 05:59 addons
-rw-r--r-- 1 root root 206611 Oct 18 06:04 config.zip
-rw-r--r-- 1 root root 13 Oct 21 06:09 .dhcp_server
drwxr-xr-x 2 root root 4096 Oct 21 04:52 log_zip
-rw-r--r-- 1 root root 62948864 Sep 20 19:01 RAIDiator-4.1.10
-rw-r--r-- 1 admin admin 10 Oct 21 06:40 ttt.log
-rw-r--r-- 1 admin admin 62943744 Oct 21 06:02 update_file
