motah33
Oct 12, 2012Aspirant
ReadyNAS Duo won't update with latest firmware
Hi, I've had this problem for a while. Every time I try to upgrade the firmaware using the GUI, I eventually get a message back saying that the update failed: Fri Oct 12 17:12:13 WEST 2012 Probl...
mdgm-ntgr
Oct 21, 2012NETGEAR Employee Retired
Hmmmm. Looks like update_files is probably 4.1.9.
Please do e.g.
Can you also do
Please do e.g.
# rm /tmp/update_file
Can you also do
# cat /var/log/raidiator_version
# cat /.cf_update_in_progress
