motah33
Oct 12, 2012Aspirant
ReadyNAS Duo won't update with latest firmware
Hi, I've had this problem for a while. Every time I try to upgrade the firmaware using the GUI, I eventually get a message back saying that the update failed: Fri Oct 12 17:12:13 WEST 2012 Probl...
mdgm-ntgr
Oct 21, 2012NETGEAR Employee Retired
See the file /.cf_update_in_progres ? Like I suspected you make a mistake entering the command. There should be two s's in progress.
