motah33
Oct 12, 2012Aspirant
ReadyNAS Duo won't update with latest firmware
Hi, I've had this problem for a while. Every time I try to upgrade the firmaware using the GUI, I eventually get a message back saying that the update failed: Fri Oct 12 17:12:13 WEST 2012 Probl...
mdgm-ntgr
Oct 21, 2012NETGEAR Employee Retired
The unit would also come and go from RAIDar (http://kb.netgear.com/app/answers/detail/a_id/20684/). If you use RAIDar quick enough you should see updating (or something like that) in the Info (far right) column.
