motah33
Oct 12, 2012Aspirant
ReadyNAS Duo won't update with latest firmware
Hi, I've had this problem for a while. Every time I try to upgrade the firmaware using the GUI, I eventually get a message back saying that the update failed: Fri Oct 12 17:12:13 WEST 2012 Probl...
mdgm-ntgr
Oct 21, 2012NETGEAR Employee Retired
Very odd.
Can you do
Do you see more examples of this?:
Can you do
# cat /etc/raidiator_version
# cat /var/log/raidiator_version
# ls -la /
motah33 wrote:
Oct 21 03:24:46 readynas kernel: Creating 2 MTD partitions on "NAND 64MiB 3,3V 8-bit":
Oct 21 03:24:46 readynas kernel: 0x00000000-0x00100000 : "P0 flash partition 1"
Oct 21 03:24:46 readynas kernel: 0x00100000-0x04000000 : "P0 flash partition 2"
Oct 21 03:24:46 readynas kernel: NEON flash: probing 8-bit flash bus
Oct 21 03:24:46 readynas kernel: CFI: Found no NEON flash device at location zero
Oct 21 03:24:46 readynas kernel: NEON flash: unknown flash device, mfr id 0x1, dev id 0x0
Oct 21 03:24:46 readynas kernel: NEON flash: Found no Atmel device at location zero
Oct 21 03:24:46 readynas kernel: This board is not supported.
