c3po's avatar
c3po
NETGEAR Expert
Jan 18, 2006
ReadyNAS LED patterns
http://www.readynas.com/forum/faq.php#What_does_this_light_pattern_mean%3F_%28LED%29 Check our FAQ, HCL and more
  • chirpa's avatar
    Sep 11, 2008
    Until I post the FAQ, here is the info for reference:
    LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks.  The number of slow blinks will be the error code.
    Current error codes:
    1 - Vendor mismatch
    2 - No disks detected
    3 - Bad contents on root partition of disks
    4 - Flash error
    5 - Unsupported RAID configuration
ProSupport for Business
