c3po
Jan 18, 2006NETGEAR Expert
ReadyNAS LED patterns
http://www.readynas.com/forum/faq.php#What_does_this_light_pattern_mean%3F_%28LED%29 Check our FAQ, HCL and more
- Sep 11, 2008Until I post the FAQ, here is the info for reference:
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code.
Current error codes:
1 - Vendor mismatch
2 - No disks detected
3 - Bad contents on root partition of disks
4 - Flash error
5 - Unsupported RAID configuration
yoh-dah
Nov 11, 2008Guide
wenel wrote: I have a problem with my DUO. I changed the RAM to 512 MB Module and now after I power on the device, disk leds are blinking: disk1 led is solid for 1s and then disk2 led is solid for 1s (disk1 led is of). Power led is off. I don't know what it means :( I've contacted the Netgear phone support, but they told me to wait and see how long it would last... :|
It's probably an incompatible memory.
