c3po
Jan 18, 2006NETGEAR Expert
ReadyNAS LED patterns
http://www.readynas.com/forum/faq.php#What_does_this_light_pattern_mean%3F_%28LED%29 Check our FAQ, HCL and more
- Sep 11, 2008Until I post the FAQ, here is the info for reference:
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code.
Current error codes:
1 - Vendor mismatch
2 - No disks detected
3 - Bad contents on root partition of disks
4 - Flash error
5 - Unsupported RAID configuration
THN
Dec 10, 2008Aspirant
I am sure that there is an expiration date on some of the FAQ and User Submitted Tips. In other words, some of them are just workarounds, which get fixed with a subsequent firm ware update.
It would be nice if there was a note on the FAQ and Tips saying that the workaround is no longer needed, or something to that effect.
Like I am looking at this security tip. Is that still needed with the latest RAIDiator?
