c3po
Jan 18, 2006NETGEAR Expert
ReadyNAS LED patterns
http://www.readynas.com/forum/faq.php#What_does_this_light_pattern_mean%3F_%28LED%29 Check our FAQ, HCL and more
- Sep 11, 2008Until I post the FAQ, here is the info for reference:
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code.
Current error codes:
1 - Vendor mismatch
2 - No disks detected
3 - Bad contents on root partition of disks
4 - Flash error
5 - Unsupported RAID configuration
Springate
Mar 09, 2009Aspirant
sorry to sound stupid but what so i do if i get the "bad contents on root partition of disks" number of flashes..
have tried to update firmware but no response from duo, cannot connect via frontview or RAIDar and only way to turn off is at the wall (not very reassuring) have lots of data on here i do not wish to lose in the process
thanks all
thanks all
