c3po
Jan 18, 2006NETGEAR Expert
ReadyNAS LED patterns
http://www.readynas.com/forum/faq.php#What_does_this_light_pattern_mean%3F_%28LED%29 Check our FAQ, HCL and more
- Sep 11, 2008Until I post the FAQ, here is the info for reference:
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code.
Current error codes:
1 - Vendor mismatch
2 - No disks detected
3 - Bad contents on root partition of disks
4 - Flash error
5 - Unsupported RAID configuration
tonasis
Apr 14, 2009Aspirant
Hi there
Has anyone seen the following LED pattern (1st line in the UK haven't, it's been passed to 2nd line in the US)
Model: ReadyNas Duo
Disk 1 green LED flashes twice, (1 second intervals)
Then all LED's flash 3 times quickly (blue pwr led, activity led, disks 1 and 2 led's)
I can't pwr this unit off either, unless I switch off from the wall socket
Can't flash/reset or do anything to the box, just keeps repeating the led pattern
This box has been replaced once already, 2 weeks ago, for exactly this same error
Any thoughts out there?
Model: ReadyNas Duo
