c3po
Jan 18, 2006NETGEAR Expert
ReadyNAS LED patterns
http://www.readynas.com/forum/faq.php#What_does_this_light_pattern_mean%3F_%28LED%29 Check our FAQ, HCL and more
- Sep 11, 2008Until I post the FAQ, here is the info for reference:
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code.
Current error codes:
1 - Vendor mismatch
2 - No disks detected
3 - Bad contents on root partition of disks
4 - Flash error
5 - Unsupported RAID configuration
markm1111
Oct 03, 2009Aspirant
Hi
This is a problem with a ReadyNas Duo. We had a blackout last night for about 90 minutes. I have the auto power on/off functionality implemented. I suspect the Duo didn't power down normally due to the blackout, as it did not restart this morning under auto power on.
I pressed the power button once, and now for the last 4 hours the duo has been running. There is no blue power light on, it just has a green led the alternates between disk 1 and 2 at roughly one second intervals.
Raidar doesn't recognise any Nas being attached.
Any clues on what might be happening, and how I get my Duo working again?
Thanks
Thanks
