c3po
Jan 18, 2006NETGEAR Expert
ReadyNAS LED patterns
http://www.readynas.com/forum/faq.php#What_does_this_light_pattern_mean%3F_%28LED%29 Check our FAQ, HCL and more
- Sep 11, 2008Until I post the FAQ, here is the info for reference:
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code.
Current error codes:
1 - Vendor mismatch
2 - No disks detected
3 - Bad contents on root partition of disks
4 - Flash error
5 - Unsupported RAID configuration
martijnh1
Oct 04, 2009Aspirant
Hi Mark,
That looks like my Duo.
It booted itself this morning and has since then been wooshing a lot, but not more then that. The blue led is blinking, all others are off. Poweroff not possible in a normal way, so..
I did log a call at support, but I have no idea when this will be responded to.
