c3po
Jan 18, 2006NETGEAR Expert
ReadyNAS LED patterns
http://www.readynas.com/forum/faq.php#What_does_this_light_pattern_mean%3F_%28LED%29 Check our FAQ, HCL and more
- Sep 11, 2008Until I post the FAQ, here is the info for reference:
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code.
Current error codes:
1 - Vendor mismatch
2 - No disks detected
3 - Bad contents on root partition of disks
4 - Flash error
5 - Unsupported RAID configuration
naburleson
Dec 11, 2009Aspirant
martijnh, My Duo started to do the exact same thing, can't figure out what the problem is. I'll boot it up and the only thing that will light up is the power LED, it will blink on and off rapidly for about a minute or two then start to blink slower and the fans will start to spin slower. If you figure anything out please let me know. Thanks
