c3po
Jan 18, 2006NETGEAR Expert
ReadyNAS LED patterns
http://www.readynas.com/forum/faq.php#What_does_this_light_pattern_mean%3F_%28LED%29 Check our FAQ, HCL and more
- Sep 11, 2008Until I post the FAQ, here is the info for reference:
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code.
Current error codes:
1 - Vendor mismatch
2 - No disks detected
3 - Bad contents on root partition of disks
4 - Flash error
5 - Unsupported RAID configuration
drc15
Jan 14, 2011Aspirant
Tonasis I have the same problem as you:
Model: ReadyNas Duo
Disk 1 green LED flashes twice, (1 second intervals)
Then all LED's flash 3 times quickly (blue pwr led, activity led, disks 1 and 2 led's)
I can't pwr this unit off either, unless I switch off from the wall socket
Can't flash/reset or do anything to the box, just keeps repeating the led pattern
Did you get any answers - can this be fixed or is it an RMA?
I have tried flashing it and the reset button but still the same pattern of lights.
Daniel
Model: ReadyNas Duo
Daniel
