c3po
Jan 18, 2006NETGEAR Expert
ReadyNAS LED patterns
http://www.readynas.com/forum/faq.php#What_does_this_light_pattern_mean%3F_%28LED%29 Check our FAQ, HCL and more
- Sep 11, 2008Until I post the FAQ, here is the info for reference:
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code.
Current error codes:
1 - Vendor mismatch
2 - No disks detected
3 - Bad contents on root partition of disks
4 - Flash error
5 - Unsupported RAID configuration
Devin1
Jan 25, 2011Aspirant
I have the exact same issue
all LEDS including power flash 3 times rapidly - then just "1" flashes slowly 3 times
Will not power off
will not reset
Can not see drive on router or Raidar
So far no help from Tech support - and it looks like others have this same problem?
Does anyone from Netgear read these posts?
Has anyone found a solution?
Will not power off
will not reset
