c3po
Jan 18, 2006NETGEAR Expert
ReadyNAS LED patterns
http://www.readynas.com/forum/faq.php#What_does_this_light_pattern_mean%3F_%28LED%29 Check our FAQ, HCL and more
- Sep 11, 2008Until I post the FAQ, here is the info for reference:
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code.
Current error codes:
1 - Vendor mismatch
2 - No disks detected
3 - Bad contents on root partition of disks
4 - Flash error
5 - Unsupported RAID configuration
tast101
Mar 02, 2011Aspirant
I assume my NV is re-syncing. I accidentally cut it on with the drives out. Now drives 1-3 and the power button are on constantly and drive 4 is flashing. And I can't locate it in raidar etc. If so any idea of how long ti would take all four drive are 500gigs. I'm waiting to migrate my data to my Ultra 4.
