c3po
Jan 18, 2006NETGEAR Expert
ReadyNAS LED patterns
http://www.readynas.com/forum/faq.php#What_does_this_light_pattern_mean%3F_%28LED%29 Check our FAQ, HCL and more
- Sep 11, 2008Until I post the FAQ, here is the info for reference:
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code.
Current error codes:
1 - Vendor mismatch
2 - No disks detected
3 - Bad contents on root partition of disks
4 - Flash error
5 - Unsupported RAID configuration
bendraper
Jul 21, 2011Aspirant
I've just put new RAM in my DUO and I first had the power light binking and the fans on full power
after an hour of nothing I unplugged it and got the 3 short and 2 long binks - indicating that it can't find any drives.
unplug and repower again gives me the power button flashing showly and fans at full power again.
Might leave it a few hours as I have 2 x 2tb disks in
any thoughts?
any thoughts?
