c3po
Jan 18, 2006NETGEAR Expert
ReadyNAS LED patterns
http://www.readynas.com/forum/faq.php#What_does_this_light_pattern_mean%3F_%28LED%29 Check our FAQ, HCL and more
- Sep 11, 2008Until I post the FAQ, here is the info for reference:
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code.
Current error codes:
1 - Vendor mismatch
2 - No disks detected
3 - Bad contents on root partition of disks
4 - Flash error
5 - Unsupported RAID configuration
logger
Oct 30, 2012Aspirant
I have a ReadyNAS NV. (The orginal one without the LCD at bottom)
All four bay lights are blinking in parallel. xx00 then 00xx. Old locked thread http://www.readynas.com/forum/viewtopic.php?f=64&t=38851 and http://www.readynas.com/download/documentation/support/ReadyNAS-LED.pdf says it is "SODIMM fails memory access test, re-seat SODIMM or replace SODIMM".
Raidar cannot see the unit. But it slight flashing decode suggests resyncing for a sungle green light. I have all four. So I guees it is not resyncing.
The light sequence appeared out of the blue with the unit running. Assuming I have diagnosed this properly am I safe to turn the unit off?
Then how do I find and re-seat the sodimm?
