c3po
Jan 18, 2006NETGEAR Expert
ReadyNAS LED patterns
http://www.readynas.com/forum/faq.php#What_does_this_light_pattern_mean%3F_%28LED%29 Check our FAQ, HCL and more
- Sep 11, 2008Until I post the FAQ, here is the info for reference:
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code.
Current error codes:
1 - Vendor mismatch
2 - No disks detected
3 - Bad contents on root partition of disks
4 - Flash error
5 - Unsupported RAID configuration
logger
Oct 30, 2012Aspirant
Did as you suggested. Ran the memory test which took about an hour. Passed (which is good) )and now has four x solid greens again and currently running a File System check. So hopefully will be up and running again shortly. Thanks for the Help.
Given that my NV unit is pretty ancient, Do you happen to know if I could put the 4hdd directly into a newer NV+ without losing all my data?
