c3po
Jan 18, 2006NETGEAR Expert
ReadyNAS LED patterns
http://www.readynas.com/forum/faq.php#What_does_this_light_pattern_mean%3F_%28LED%29 Check our FAQ, HCL and more
- Sep 11, 2008Until I post the FAQ, here is the info for reference:
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code.
Current error codes:
1 - Vendor mismatch
2 - No disks detected
3 - Bad contents on root partition of disks
4 - Flash error
5 - Unsupported RAID configuration
mdgm-ntgr
Oct 30, 2012NETGEAR Employee Retired
You could put them in a NV+ (v1 - silver chassis) but not a NV+ v2 (charcoal chassis). The NV+ (v1) itself is EOL now so would be getting increasingly hard to find new.
See http://www.readynas.com/kb/faq/boot/how_do_i_migrate_disks_over_from_an_existing_readynas_to_another
A good description of a range of ways on how to tell the difference between a NV+ (v1) and a NV+ v2 can be found here: How to tell whether I have a Duo v1 or Duo v2 or NV+ v1 or NV+ v2
