c3po
Jan 18, 2006NETGEAR Expert
ReadyNAS LED patterns
http://www.readynas.com/forum/faq.php#What_does_this_light_pattern_mean%3F_%28LED%29 Check our FAQ, HCL and more
- Sep 11, 2008Until I post the FAQ, here is the info for reference:
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code.
Current error codes:
1 - Vendor mismatch
2 - No disks detected
3 - Bad contents on root partition of disks
4 - Flash error
5 - Unsupported RAID configuration
etardieu
Nov 14, 2012Tutor
Yes, I found the Led pattern documentation after I posted, I thought it was a corrupt boot as well. However, I can't see the unit with RAIDar.
In the meantime, I started transfering the data to another disk using RT-Linux. But it does take a very long time to do it via usb2 to another usb2 external drive :cry:
