c3po
Jan 18, 2006NETGEAR Expert
ReadyNAS LED patterns
http://www.readynas.com/forum/faq.php#What_does_this_light_pattern_mean%3F_%28LED%29 Check our FAQ, HCL and more
- Sep 11, 2008Until I post the FAQ, here is the info for reference:
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code.
Current error codes:
1 - Vendor mismatch
2 - No disks detected
3 - Bad contents on root partition of disks
4 - Flash error
5 - Unsupported RAID configuration
cpu8088
Nov 27, 2014Virtuoso
hi
i have a 312 that cannot operate now
it was running ok and then the 2 hard disks stopped with 2 lights on, namely the power and disk 1.
so i tried to do factory reset but the hard disks not spinning, fan is on and the unit just freeze with power light on and disk 1 led on only. that has been done many times. same result the unit just does not boot up.
took out the 2 hard disks and checked, put them into my old trusty duo v2 and factory reset, installed and running ok. so the hard disks are functional.
is the 312 dead with hardware malfunction? or firmware corrupt? it has 6.2.0 installed.
