c3po
Jan 18, 2006NETGEAR Expert
ReadyNAS LED patterns
http://www.readynas.com/forum/faq.php#What_does_this_light_pattern_mean%3F_%28LED%29 Check our FAQ, HCL and more
- Sep 11, 2008Until I post the FAQ, here is the info for reference:
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code.
Current error codes:
1 - Vendor mismatch
2 - No disks detected
3 - Bad contents on root partition of disks
4 - Flash error
5 - Unsupported RAID configuration
mdgm-ntgr
Nov 27, 2014NETGEAR Employee Retired
Sounds like hardware failure.
When did you update to 6.2.0?
If you boot it with no disks installed, does it come up in RAIDar with "No Disks Detected" in the Info (far right) column?
