roger_armstrong
Apr 13, 2012Aspirant
ReadyNAS loses network connectivity
We're using a ReadyNas 6 Ultra Plus for backup of ESX servers (using ghettoVCB with the ReadyNAS mounted as an NFS datastore) and a ReadyNAS Ultra 4 plus as an NFS datastore. Unfortunately, both Ready...
Jun 28, 2012Guru - Experienced User
What firmware are you running? I usually use FireFox, and don't see this issue with my Pro.
kakemann81 wrote: I have the same problem. Just bought the NAS, so I'm a bit dissapointed with this.
I can access the folders on it, but not the control panel in chrome or iexplore.
Happens after a few days.
