roger_armstrong
Apr 13, 2012Aspirant
ReadyNAS loses network connectivity
We're using a ReadyNas 6 Ultra Plus for backup of ESX servers (using ghettoVCB with the ReadyNAS mounted as an NFS datastore) and a ReadyNAS Ultra 4 plus as an NFS datastore. Unfortunately, both Ready...
tfierens1
Jun 29, 2012Aspirant
My model is the readynas Ultra 6.
In regards to 4.2.21 not applying, unless I'm missing something here, this link seems to say otherwise http://www.readynas.com/?p=6469. Now I'm going to go reboot my drive as I cannot access it at this time but when I applied 4.4.21, it did say "applied successfully."... Now whether or not it did is another story. One thing I did notice is that I had to download this manually as it was t appearing via the automatic update section.
I don't think I'm in the wrong thread as the title of this thread is "losing network connectivity" which exactly what is happening to me and while the described behaviour might be slightly different they are still very similar because a) it does lose network connectivity, b) it seems to happen when copying large files and c) it has only started to happen since upgrading to 4.2.20.
Thanks.
Thanks.
