Polaris1980
Sep 26, 2015Aspirant
Readynas Malfunction- Frontview does work but disks no longer visible
Hello all I am a bit in a bind. Readynas is no longer visible in the network. Front view is accessible. But in volumes-> volume setting it says that I have: 0 MB (0%) of 0 MB used The six disks ar...
- Sep 29, 2015contacted support. they where excellent.
the problem was that 98% full is way to full for the system to operate. (max 90%). so the system froze.
nothing wrong with Nas or with disks. took my loss and did a factory reset. works fine now. lost 20% of data ( not backed up elsewere). txs for the reply StephenB and Mdgm
Polaris1980
anybody? other post regarding this subject are very specific to there systems. I do not have any other option to contact my NAS
- StephenBSep 26, 2015Guru - Experienced User
Assuming no backup - If you are the original purchaser, I suggest opening a support case (support.netgear.com). They likely will charge, but I think that's your best chance of getting your data back.
