tonitheitgirl
Jul 29, 2015Aspirant
ReadyNAS Netgear 2120 Stops responding to all traffic (iSCSI / Web interface) #25509387
I have a RN2120 running 6.2.4 with 4 2TB disks. (one of 5 that we have running in our estate, none of the others I'm experiencing this on) This unit is 2 years old.
I started to see this behavi...
OOM-9
Jul 29, 2015NETGEAR Expert
How are you using the iSCSI? Is it a Windows file share, VMs or backup?
Depending on how it is being used may determine recommendations.
- tonitheitgirlJul 29, 2015Aspirant
its one big iSCSI LUN being used for veeam backup and replication. There is a single veeam proxy windows (2012) machine connected to it.
- OOM-9Jul 29, 2015NETGEAR ExpertIt would typically be recommended to keep the volume closer to 80% of volume capacity. There are general performance and reliability issues that may come up if you exceed that threshold.
This is normally not the best option if data is already on the iSCSI. Other options that you can look at changing to help in these cases; disable the checksum that is under the [System/Volumes/Volume Properties/Settings/Summery] and under disable bit rot protection under [Shares/{share} Settings/Properties]
There can be more things that we could go into, but these items are the more common items that had issues similar to what you have mentioned.- mdgm-ntgrJul 29, 2015NETGEAR Employee Retired
Can you send your logs in (see the Sending Logs link in my sig)?
