beepmeep
Dec 10, 2017Aspirant
Readynas Network 100mbit issue
Hi everybody, As far as I can see from the documentation of this NAS, it should be capable of running Gigabit speeds on the network. This, however, is not what I'm experiencing.. My test setu...
- Dec 10, 2017
Can you try installing NasTester from http://www.808.dk/?code-csharp-nas-performance, and use it to test your NAS performance. You can post back the screenshots here (or just give us the speeds it measured).
Have you confirmed the network speed to between the NAS and the switch? If the NAS says 100 mbit, then try switching to a different ethernet cable. If there's an open wire, the autonegotiation will often negotiate 100 mbits.
You could also enable ssh, and install iperf on the NAS. That would let you do an end-to-end performance check of the network.
If you are using jumbo frames, try changing back to the standard 1500 byte MTU.
beepmeep
Hi,
I didn't realize I could install packages on the NAS, I installed Iperf and measued 980mbit. In the meantime before your reply, I changed port on the nas to Port 1 (was using port 2). I tried changing back to Port 2 and could measure 96mbit, so I suppose I'm dealing with a faulty port on the NAS..
Thanks for your help, the performance tester will ease troubleshooting in the future :)
Dec 10, 2017Guru - Experienced User
You do want to be cautious here. You don't want to upgrade libraries Netgear hasn't customized, and often times there are issues if the libraries the ReadyNAS application needs conflict with the versions the user-installed packages need. Another aspect is that the OS partition is only 4 GB, and really weird things can happen if it gets too full.
But iPerf is safe enough, I've had it installed on my OS 6 NAS for quite a while. As you say, it is useful for troubleshooting.
