Yoshi900
May 05, 2020Aspirant
Readynas not using full capacity
Hi, It seems like my readynas 314 will not expand to the new size. I started with 6tb - 2tb - 6tb - 2tb which gave me ~9tb of space Then I wanted to upgrade the 2tb disks to 4tb disks. I did thi...
Yoshi900
May 06, 2020Aspirant
So I already have the 6tb and the 4tb in the nas, it never did an increase to 12.7tb.. it is currently at 10.2tb
From what I have read it looks like I have to do a factory reset to get the extra storage which is pretty annoying.
May 06, 2020Guru - Experienced User
What is a bit puzzling here is why you saw any increase in space when you upgraded the first 2 TB drive. You shouldn't have, unless you previously had 4 TB drives in the array.
Can you download the log zip file and post mdstat.log? Cut and paste it in a reply (the </> tool in the toolbar is handy for this).
