JConfidence's avatar
JConfidence
ReadyNAS NV - New power supply Power LED 3 fast flash
I've had the power supply on my readynas NV die twice now, but that's to be expected I think when it's around 12 years old. This last round I got the new PWS and installed it. Now when the device tries to boot I get all 4 disk drive LEDs lit, and then the power button does this 3 quick flash then pause, 3 quick flash, pause, etc. Just loops. Not able to find it in Raidar. It's clearly having an issue booting but I'm not sure how to recover. The LED PDF suggested to re-seat the ram. Going to do that next, then it suggested doing a reset of nand. I'm worrid that my old raid is going to disappear and I'll still lose all my data. Any thoughts? Will an Nand recovery lose my raid config? Am I out of luck? Is the 3 flash something else? Thanks!
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Well if the boot menu works you may wish to run the memory test twice.
    USB Boot Recovery doesn't touch the disks. All that does is overwrites the firmware on the flash.
    Do you recall which firmware you were running?
    • JConfidence's avatar
      JConfidence
      I was running 4.1.1.4 on the system. I attempted to do a USB recovery. I followed the procedure, it appeared to load the image from USB and then shutdown. I hit the power to come back online and still the same flashing power light. No hard drives lit up. The LED guide is pointing to Memory, or Recovery (which I just attempted) or Power supply. The power supply is brand new from Netgear so I'm hoping/guessing it's no that? Seems odd my ram would just give up on me, but maybe worth just replacing anyway. Not sure what else to do.
ProSupport for Business
