havenuke
Jul 22, 2013Aspirant
ReadyNAS NV+ freezes after 5 minutes.
I have a ReadyNAS NV+ v1 and it will lock up after restarting it. It will work until I access it via wireless network. I'm running Win 7 Home Premium. Laptops connect wirelessly to a netgear router...
Jul 22, 2013Guru - Experienced User
Did support.netgear.com tell you they would charge for it?
Deleting the logs from Frontview can help (backup and the system logs). DON'T attempt to download them, as if the OS really is full you could make things much worse.
OS reinstall from the front panel will clean up some stuff. If you have ssh installed, you could find more stuff to delete. ReadyDLNA database for one.
- Jan 17, 2024Retired_Member
