havenuke
Jul 22, 2013Aspirant
ReadyNAS NV+ freezes after 5 minutes.
I have a ReadyNAS NV+ v1 and it will lock up after restarting it. It will work until I access it via wireless network. I'm running Win 7 Home Premium. Laptops connect wirelessly to a netgear router...
Jul 23, 2013Guru - Experienced User
You might want to log in with ssh, and then type
df . -h
That will tell you the % of the OS partition that is being used (the quota check and file system checks in Frontview apply only to the data partition, not the OS).
df . -h
- Jan 17, 2024Retired_Member
