Dane2000's avatar
Dane2000
ReadyNAS NV+: how to remove not exists volume and disks (disk failed)
Hello all! My Dad asks me for help, but I don't know what was happened and what what should I do. He has a ReadyNAS NV+ with 4 disks without RAID (standalone disks). One of them has dead. I'd took ...
  • StephenB's avatar
    Sep 09, 2019
    One option is to upgrade the NAS to the final firmware (4.1.16) if it isn't running that already, and then do a factory default procedure to rebuild the NAS from scratch.  Off-load all the data first of course.
    If you stick with flexraid, you'd need to install RAIDar 4.3.8 on PC to get the NAS into that mode.  https://kb.netgear.com/20684/ReadyNAS-Downloads  Also with flexraid and independent volumes, I recommend doing the factory default with only one disk in place, and adding the remaining disks later.  That insures that you don't accidentally end up with RAID-1 or RAID-5.
    If you plan on upgrading disks, you need to stick with drives that are no larger than 2 TB.  NAS-purposed disks (Seagate Ironwolf or WDC Red) are good options.  Don't bother with the HCL, it hasn't been updated for several years.
ProSupport for Business
