robmorris77
Jan 14, 2016Aspirant
Readynas nv+ ... reset battery ?
Hi, Hopefully someone will be able to help me with the following query ? I have a ReadyNAS NV+ with the same problem as detailed in this thread : https://community.netgear.com/t5/Using-yo...
JennC
Jan 14, 2016NETGEAR Employee Retired
Hello robmorris77,
Welcome to the community!
https://community.netgear.com/t5/Using-your-ReadyNAS/WTB-ReadyNAS-NV-power-supply/td-p/921317#p337936 should now be visible to you.
Please also see HOW TO RESET CMOS TIMER IN ReadyNAS NV, it is similar to NV+. That must be the one you need.
robmorris77
Thanks I'll give that a try and update the thread once I'm able to report back in a few days !
I'm probably going to buy a pair of RN314's with 4x WD RED 4TB HDD's to consolidate my handful of NV+'s so may wait to do that first so that I can ensure all my data is backed up before I play with the faulty unit further.
Thanks again
Rob
